2002 Dodge Ram GEARS RATTLING
105,000 MILES • V8 • 2WD • MANUAL
GSTONE
i'VE ALREADY REPLACED CLUTCH. PROBLEM IS INTERNAL. SHOULD I REBUILD OR REPLACE TRANS. ? HOW CAN I DONATE? DON'T USE CARDS
Nov 28, 2008 at 3:24 AM
DOCFIXIT
  • 18,828 POSTS
Sounds like worn syncros and bulk rings. Any dropping out of gear on decell?
Nov 29, 2008 at 6:09 AM
GSTONE
[quote:4b2758c9cd="GSTONE"]Transmission problem
2002 Dodge Ram V8 Two Wheel Drive Manual 105000 miles
i'VE ALREADY REPLACED CLUTCH. PROBLEM IS INTERNAL. SHOULD I REBUILD OR REPLACE TRANS. ? HOW CAN I DONATE? DON'T USE CARDS[/quote:4b2758c9cd] HAVEN'T HAD ANY PROBLEM JUMPING OUT OF GEAR. RATTLES MOSTLY IN 1-3 BUT STILL HEAR IT IN UPPER & REVERSE
Nov 29, 2008 at 10:43 AM
DOCFIXIT
  • 18,828 POSTS
Replacement trans would be less expensive. Have you had a Tech diagnose the problem? It may save time and money to have a professional look at.
Nov 30, 2008 at 5:24 AM
