2002 Dodge Ram Fuel injector??
126 MILES • 6 CYL • 2WD • AUTOMATIC
DYNOGT16
I have an 2002 dodge ram 1500. Friday dec. 11. It shut off going down the road. Now it barely Idiols. Runs rough and cuts out. There is gas in my oil. Hooked it up to. code reader. cylinder 5 and 6 injectors bad it say but would that cause this problem??
Dec 15, 2009 at 5:32 AM
  • 110,251 POSTS
If the injectors are pumping too much fuel, it can make it into the oil if not burned. As far as the injectors, make sure they are getting power before replacing them.
Let me know what you find.
Dec 18, 2009 at 1:11 AM
DYNOGT16
I replaced them. Check engine light is off when running but still runs bad. The cat. Clanks at low rpms rpms go up and down. PLus a lifter is ticking. So idk.
Dec 20, 2009 at 2:45 AM
