2002 Dodge Ram engine will not turn over
149,000 MILES • V8 • 4WD • AUTOMATIC
L.LEWIS
Have relace starter ,batterie,starter relay truck will not even turn over no click nothing
Jul 8, 2009 at 5:43 AM
JDL
  • 16,098 POSTS
Did you check the circuits at the starter relay for voltage? Just unplug the relay, use a testlite. The 30 terminal is hot all the time. The 86 terminal goes hot with the key in the crank position. The point is, with the key in the crank position, two of those terminals should be hot. Have you tried to crank it in neutral?
Jul 8, 2009 at 7:09 AM
