2002 Dodge Ram ENGINE LIGHT ON/ ABS LIGHT ON / BRAKE LIGHT
79,000 MILES • V8 • 4WD • AUTOMATIC
TREDEW
THE CHECK ENGINE LIGHT IS ON STEADY. AFTER I START MY TRUCK THE ABS LIGHT AND BRAKE LIGHT THEN COME ON. ALSO THE SPEEDO DOES NOT WORK PROPERLY (JUMPS ALL OVER THE PLACE). THE ODMETER SOMETIMES REGISTERS BUT MOSTLY NOT. ALSO THE TRUCK SEEMS TO HAVE TROUBLE SHIFTING. AFTER 30 SECONDS OR SO OF DRIVING THE POWER LOCKS KICK IN (NORMAL) BUT I CAN SEE THE SPEEDO JUMP UP ALL THE WAY UP THEN BACK DOWN. SEEMS TO BE SOME SORT OF GROUND PROBLEM JUST DON'T KNOW WHERE TO LOOK. THANKS IN ADVANCE.
May 7, 2009 at 9:39 AM
MERLIN2021
  • 17,250 POSTS
You can try a self-diagnostic test. To activate self diagnostic program:
With the ignition switch in the OFF position, depress the TRIP and RESET buttons.
While holding the TRIP and RESET button turn the ignition switch to the ON position.
Continue to hold the TRIP and RESET buttons until the word CODE appears in the odometer windows (about five seconds ) then release the buttons. If a problem exists, the system will display Diagnostic Trouble Codes (DTC's). If no problem exists, the code 999 (End Test) will momentarily appear. Post all codes found, it sounds like the VSS(vehicle speed sensor).
May 9, 2009 at 2:14 AM
TREDEW
I depressed the reset and step buttons (they are located on the overhead console) with the ign off then turned the key to on. The overhead console then displayed PASS. All conditions remained the same. I did not see anything happen in the odmeter window. It never came up with any code.
May 9, 2009 at 3:05 AM
MERLIN2021
  • 17,250 POSTS
If yours wont display the codes this way, go to Autozone, they read them for free, get the codes and post here.
May 9, 2009 at 4:08 AM
