THE CHECK ENGINE LIGHT IS ON STEADY. AFTER I START MY TRUCK THE ABS LIGHT AND BRAKE LIGHT THEN COME ON. ALSO THE SPEEDO DOES NOT WORK PROPERLY (JUMPS ALL OVER THE PLACE). THE ODMETER SOMETIMES REGISTERS BUT MOSTLY NOT. ALSO THE TRUCK SEEMS TO HAVE TROUBLE SHIFTING. AFTER 30 SECONDS OR SO OF DRIVING THE POWER LOCKS KICK IN (NORMAL) BUT I CAN SEE THE SPEEDO JUMP UP ALL THE WAY UP THEN BACK DOWN. SEEMS TO BE SOME SORT OF GROUND PROBLEM JUST DON'T KNOW WHERE TO LOOK. THANKS IN ADVANCE.
May 7, 2009 at 9:39 AM
