I have a problem with my truck. I now have no running lightg and no rear lh turn signal. Can you help me?
Feb 24, 2009 at 6:18 AM
MIKE H R
MEMBER
what I would do is check the fuses, if ok then proceed to check the voltage from the fuses to the switch then move back towards the back to see if there is any corroded or broken wires. check all the wiring connections, sometimes they will work loose.
