Misfire at 4
A misfire in a specific cylinder should lead you to check the spark plug, fuel injector and compression. check it then report back.
NOTE: Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Dec 9, 2019 at 5:05 AM
(Merged)
