2002 Dodge Ram Cruise control
111,000 MILES • V8 • 2WD • AUTOMATIC
CRAIG2083
My cruise control does not engage. When I push the on button the light illuminates, then when I push set nothing happens. Ive tried pushing every cruise button on the colum. I checked the fuse box under the hood and theres no fuse for cruise control.
Sep 26, 2009 at 10:19 AM
KHLOW2008
  • 41,812 POSTS
Hi craig2083,
When the main switch is indicating, it should not be a fuse problem.
A scan tool would be required to scan and retrieve trouble codes to proceed with diagnostics.
Possible Causes:
• Ground Circuit Open
• S/C Brake Switch Output Circuit Open
• S/C Power Supply Circuit Open Or Shorted
• S/C Servo Defective
• S/C Vacuum Solenoid Control Circuit Open Or Shorted
• S/C Vent Solenoid Control Circuit Open Or Shorted
• Brake Switch Defective Or Out Of Adjustment
• Defective PCM
Sep 27, 2009 at 3:23 AM
