When driving down the road the A/C system works normally, cooling well, indicating that it has a normal refrigerant charge and that the compressor is functioning ok. However, at idle the compressor short cycles to the point of not cooling. The engine cooling fan seems to be spinning properly also. Could this be a pressure switch or air flow problem? Also the pressure switch has three wires connected to it. Is this a switch which measures both high and low pressure?
Apr 29, 2009 at 2:24 AM
