2002 Dodge Ram compressor short cycle at idle
DAVANZ
Air Conditioning problem
2002 Dodge Ram 6 cyl Two Wheel Drive Automatic
While driving down the road the A/C system works totally normal, which indicates to me that the system has an adequate charge and the compressor is functioning properly. However at idle the compressor short cycles to the point of not cooling. The engine cooling fan seems to be spinning normally also.
Apr 29, 2009 at 2:14 AM
DOCFIXIT
  • 18,828 POSTS
Hi
System maybe getting to hot raising high side pressure and the high pressure switch is cutting off compressor. With engine at operating temp. and off turn fan by hand should fill resistence and no free wheeling. If easy to turn or any movement side to side then replace fan clutch. That will pull cool air across condensor at low speeds.
Let me know if need more help
Thanks for donate
Apr 29, 2009 at 2:34 AM
