2002 Dodge Ram CODES PO505
185,000 MILES • V8 • 2WD • AUTOMATIC
BRETT 1962
HAD RAN AN OBDII SCAN IT CAME UP WITH PO505 IDLE CONTROL SYSTEM PROBLEM HAD CHECKED AWHILE BACK AND IT SAID IDLE AIR CONTROL MOTOR REPLACED IT CLEARED THE CODES AND A FEW SECONDS LATER IT CAME BACK ON ANY IDEAS ARE GREATLY APPRECIATED,Thanks Brett
Dec 27, 2007 at 12:35 PM
BLACKOP555
  • 10,386 POSTS
first you should attempt to clean out the throttle body and reset the code, post back with your results.
Dec 27, 2007 at 2:23 PM
