2002 Dodge Ram clunking noise
82,000 MILES • V8 • 4WD • AUTOMATIC
MSDEITK1
when i go over sharp bumps i get a clunking noise. balls joints are new shocks are new. all bushings look great could it be in torsion bars one is in farther then the other. i dont know where they are supose to be from factory. and how far can you go without problems
Apr 22, 2008 at 12:48 PM
BLACKOP555
  • 10,386 POSTS
put vehicle in 4wheel drive hubs locked and everything, then go under there and check for play in your universal joints, if they are loose and sloppy they need replacing.
Apr 22, 2008 at 1:45 PM
MSDEITK1
[quote:f232d955b4="msdeitk1"]Suspension problem
2002 Dodge Ram V8 Four Wheel Drive Automatic 82000 miles
when i go over sharp bumps i get a clunking noise. balls joints are new shocks are new. all bushings look great could it be in torsion bars one is in farther then the other. i dont know where they are supose to be from factory. and how far can you go without problems[/quote:f232d955b4]
u-joints are good. it sounds like a ball joint clunking thats why there all new. any other suggestions thanks
Apr 23, 2008 at 2:05 PM
