acceleration vibration from 30 to about 40 MPH
85,500 MILES • V8 • 2WD • AUTOMATIC
ASSOCER
Accelerating from 0-29 is completely normal but from 30-about 40 my truck starts vibrating. Its not the most violent shaking Ive seen, but it shakes hard enough to rattle some of the plastic pieces in the cab like the cupholders. While Im between 30 and 40 and its shaking, the second I let off the gas pedal its as smooth as ever, but as soon as I hit the gas pedal again it starts vibrating. It just started doing this Saturday night, so its been doing it for about 2 days. I have a 1500 mile drive in about a week and need to get this fixed asap. Thanks for your help.
Jan 31, 2010 at 7:20 PM
  • 110,248 POSTS
I can offer some possible explanations for the behavior you're experiencing:
Wheel Balance or Alignment Issues
Tire Issues
Driveshaft or U-Joint Problems:
Transmission Issues:
Feb 2, 2010 at 12:27 AM
ASSOCER
I actually took it to a local tire shop so I could have the tires checked. The tires are just over a year old so I didn't think it was that but had them looked at anyways. While they had it up on the lift they checked out the drive shaft and told me that the bearing in the front Ujoint was shot and needed to be replaced. They also recomended replacing the rear Ujoint while they had the drive shaft off, so I had them do that one too. Is that what you would recomend too? It fixed the problem, there are no more shakes and vibration. I had a difficult time understanding why it would only shake between 30-40mph, can u explain?
Thanks
Feb 2, 2010 at 4:40 PM
