2002 Dodge Ram ac leak
108,000 MILES • 6 CYL • 4WD • AUTOMATIC
WKOTZMAN
2002 dodge ram 2500 w/ 5.9 diesel engine. I know there is a leak in ac system. Sometimes it will hold freon for 2 days, sometimes a couple of weeks. I put dye in and ran system for 15 minutes. Checked system once the sun went down with uv light and found no signs of leaks under hood. Is there a way to check evaporator without taking entire dash apart? Thanks for any help.
May 31, 2010 at 2:12 PM
  • 31,937 POSTS
Hi there,
take it to a A/C repairer as they should have an electronic gas sniffer, this is placed near the vents and it will beep if there is refrigerant in the air.
mark (mhpautos)
May 31, 2010 at 2:15 PM
