2002 Dodge Ram Won't Start
TANKASS
Truck sat out all weekend and now it will not start.Checked the code and got this one but the CO2 has nothing to do with it starting. Just turns over and over. Was thinking maybe coil but just like that..kinda wierd..But with blowing snow and damp conditions you never know.Any idea guys and if it's the coil anyone know where it is?.I could follw the coil wire but on a 02 Dodge theh distributer is at the back of the engine compartment and it would be a hell of a climb.
TTFN
Feb 26, 2007 at 9:12 AM
BHUGG
  • 157 POSTS
Check all the cars fuses. There should be 2 fuse boxes. look for the one inside the car and also look under the hood for another fuse box. Make sure we are good there.
Do you get a spark?
Feb 27, 2007 at 2:22 AM
Suggested Repair
Check the interior and under-hood fuse boxes, then confirm whether the engine has spark before replacing the coil.
Conversation Summary
A 2002 Dodge Ram 4x4 cranks but will not start after sitting over a weekend in snow and damp conditions. The owner found code P0139 and wondered if the coil was at fault, noting the distributor is hard to reach at the rear of the engine bay. The expert advised checking both fuse boxes and verifying spark.
