2002 dodge ram 4.7 liter 1500
JEFF02RAMMAN
:( i would like to know if it is normal for my 2002 ram to be getting only 10 to 12 mpg a tank! My fiance has a 02 model also base model with over 100K miles on hers and she is achieving 17 mpg on highway. I am saddened by this and am thinking of trading it i have barely had 2 mnths. A 4.7 liter should do better from my understanding. Also i notice hesitation and like the tranny is straining what gives. I put a K and N airfilter nadda nuttn! Any advice . Maybe put it on diagnostics ! Any help or advice i will take thank You !!
Jun 15, 2006 at 10:17 AM
CAPTAINV
I have the same vehicle model with a 45RFE trans. If the overdrive is turned off or not functioning gas mileage will be about 12/13 mpg. With overdrive engaged mileage 18/24 mpg should be obtained. Normally overdrive is engaged when truck starts and must be manually turned of for pulling trailer,etc. (button is on end of shift lever.
Dec 8, 2008 at 5:45 AM
