2001 Dodge Ram won't start
148,000 MILES • V8 • 4WD • MANUAL
DWGROVESLC
i've just finished replacing the engine (myself) and drove the truck for about 30 miles when it just stalled out and would not start back up. i then replaced the distrubutor again and the ignition coil and the pcm. this time it went 50 miles and stalled. so i went back to my haynes manual and found the asd relay may be to blame but i changed the relay it started up, ran for 3 seconds then shut right back off. any more suggestions. truck ran fine before swap.
Mar 2, 2009 at 5:41 AM
  • 110,251 POSTS
Hi:
Has the check engine light come on? Also, have you checked for spark and fuel pressure?
Mar 3, 2009 at 2:06 PM
