2001 Dodge Ram water pump
JRJ976
Engine Cooling problem
2001 Dodge Ram V8 Four Wheel Drive Automatic
I just changed my water pump but it still is leaking. What else could the problem be?
Feb 1, 2010 at 4:53 AM
CYBER TECH
  • 23 POSTS
The actual pump is leaking? if that is the case you have a faulty pump.
If the leak is slightly behind the pump it is probably the timing cover gasket that is leaking.
Feb 1, 2010 at 10:11 AM
