We had are truck hooked up to a scanner and the code said a small and large vapor leak I don't know were to began to look.
Friday, February 27th, 2009 AT 10:27 AM
MECHANIC
Hi:
That sounds like an EVAP code. Listen, if that is the problem, I will make a recommendation. Take the car to a shop that can fog the system. Where ever the leak is, fog will come out and it's easy to find. If you try to find it on your own, it will drive you crazy. It could be as simple as a gas cap, or a pin hole in one of the EVAP hoses that you will never see.
