2001 Dodge Ram Vacuum
2001 DODGE RAM
154,000 MILES • V8 • 2WD • AUTOMATIC
WSYSAK
My 2001 Dodge Ram Pickup 5.2 litre has an issue with the vents switching from vent to defrost. I have changed the PCV Valve without any change. If i disconnect the PCV and plug the manifold the AC works fine. What is the issue?
Aug 18, 2008 at 9:37 AM
TBUBBACANGO
sounds like a vacuum leak
you might replace the check valve going to the ac system
dodge has a larger check valve whitch act as a small vacuuum chamber
you will need to get a vac hose adapter for both ends
of valve
i did this change over with wonderful results
Aug 19, 2008 at 8:40 AM
