2001 Dodge Ram starting issues
150,000 MILES • V8 • 4WD • AUTOMATIC
GEOFFREY PICCOLO
everytime it rains out my truck will not start, does not matter if it is cold or warm out
Apr 4, 2009 at 10:34 AM
  • 75,988 POSTS
Rain or Shine do below to determine if its fuel or spark then comeback.
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Apr 4, 2009 at 12:55 PM
