2001 Dodge Ram Stall on Braking
173,000 MILES • V8 • 2WD • AUTOMATIC
WYCHEJT
When I start up the truck initially it will stall out within 3 seconds on the second startup it will idle well then when placed in drive and given a little bit of gas followed by letting off of the gas it will stall again. If driving will stall out upon braking. Really need to figure out the problem.
Aug 24, 2010 at 2:51 AM
  • 110,251 POSTS
Have you checked fuel pump pressure? Has the check engine light come on? Have you checked for vacuum leaks?
Aug 24, 2010 at 1:15 PM
