2001 Dodge Ram Squeaky Harmonic Balancer
2001 DODGE RAM
95,000 MILES • V8 • 2WD • AUTOMATIC
DAKOTA DAN
I have tried 2 separate serpatine belts and still have a squeaky/squealing harmonic balancer. Any suggestions? Thought about swapping balancers but look for suggestions first. Thanks
Oct 12, 2010 at 8:59 AM
  • 110,240 POSTS
Is the belt the issue? Does the sound exist if you remove the belt and start if for a second?
Oct 20, 2010 at 12:18 AM
DAKOTA DAN
A little trouble shooting has led me to believe it is not the balancer. 2 different belts..same squeak/squeal..how the hell to you check all the pulley allingments? That is what I am thinking now...
UUUUGH
Oct 20, 2010 at 1:35 PM
  • 110,240 POSTS
To identify which belt is the problem, start the engine, open the hood, and pour a small amount of water on one at a time. Which one changes the sound?
As far as pulley alignment, the best way is if you can fit a straight edge across them. If there isn't room, you have to do it by eye.
Oct 20, 2010 at 4:10 PM
