2001 Dodge Ram Sqeaking
77,000 MILES • V8 • 2WD • AUTOMATIC
SPIDEYBLUE5
I have a 2001 Dodge Ram 1500, it has 77000 miles and the front driver's side suspension is making a sqeaking/grinding noise when it bounces, it has also started making a sqeaking noise when I turn the wheel either direction, but only on the driver's side, what could be the problem?
Aug 10, 2009 at 10:12 AM
  • 110,248 POSTS
Chances are the sway bar bushings are dry. Try spraying them with something like WD 40 to see if that helps.
Aug 11, 2009 at 11:18 AM
