2001 Dodge Ram shaking after plugs and wires change
92,000 MILES • V8 • 2WD • AUTOMATIC
GOMEZ1980
To cut the story short. I replaced my spark plugs and wires. After replacing the plugs i noticed a bit of hesitation then just bad performance. After a few minutes of driving the truck it felt like it was misfiring, Then check engine light came on and started flashing. Now i havent checed the DTC yet. I rechecked to make sure if i had the plugs in the right order and all was done correct. Now when I went further to diagnose the issue. I notice the spark plugs i used where not the ones recommended by the manufacture. Instead i used BOSH Platinum plus (4030) which does indicate is for my make and model and engine size. But when i put then side by side the bosh platinums looks slightly shorter then the champions (the ones recommended by the manufacturer).
Now I know I pretty much answered my own question. But has anyone ever had this problem with a dodge ram? From using a different brand spark plugs other then whats recommended.
Apr 7, 2009 at 10:52 PM
BMRFIXIT
  • 19,053 POSTS
You answered your own question for sure
check engine light on and flashing
is an indication of misfire to a point of damaging the catalyst and truck should not be driven in this condition
I would replace spark plugs and coil too
good luck
let me know
Apr 7, 2009 at 11:02 PM
GOMEZ1980
[quote:91c51c24c0="BMRFIXIT"]You answered your own question for sure
good luck
let me know[/quote:91c51c24c0]
Thanks for the quick reply. I guess i should stop second guessing myself. But i will update ASAP.
Apr 7, 2009 at 11:21 PM
BMRFIXIT
  • 19,053 POSTS
You are welcome
Coil is a common failure
we always replaced them with 100K tune up
good luck
let me know
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
_________________
Apr 7, 2009 at 11:46 PM
LOWCOST67
  • 35 POSTS
if it ran fine before.the common mistake is to have two plug wires crossed. it will kick the exact code you said good luck
Apr 9, 2009 at 3:31 PM
