2001 Dodge Ram Sensor Location
124,000 MILES • 6 CYL • 2WD • MANUAL
DBOSTON
I have a code indicating that the aimbient air temperature sensor voltage is out of range. I have had no success locating the sensor. My ALLDATA subscription says that it located on the underside of the hood near the striker latch and that the sensor bracket is attached under the right side striker latch mounting bolt. The bolt is tight and there is no evidence that a bracket was ever mounted there and the only wiring going to the hood is for the under-hood light.
Jul 4, 2008 at 9:43 AM
DENNYP
  • 1,824 POSTS
look around in front of the condenser and radiator.
Jul 11, 2008 at 6:56 AM
