2001 Dodge Ram Please Help
11,400 MILES • V8 • 2WD • AUTOMATIC
JEFFSCHEIDERER
Just bought this truck 2 yrs ago. When it's cool it runs fine. After warmed up it stalls, backfires, runs as if only on two cylinders. What do you think the problem is and how can it be fixed?
Jun 23, 2009 at 3:13 AM
JDL
  • 16,098 POSTS
Hello, how long since a tune-up? Any codes? Can you put a scanner on it, to look at live engine data? As far as ignition, I have used a dmm as a quick test, it's an inductive reading at the plug wires. You don't take the plug wire loose and don't penetrate the insulation, the reading is inductive, you just touch the meter lead to the wire. Compare the readings.
Can you check fuel pressure? You need to test when the problem is ongoing.
Jun 23, 2009 at 3:31 AM
