The overdrive shift solenoid is located in the pan of the transmission here is a guide to help get you started and the location of the solenoid in the diagrams below.
Image (Click to enlarge)
May 1, 2021 at 11:29 AM
✓Experienced Mechanic
Below you will find the process to not only locate the solenoid but replace it as well. You need to remove the valve body to do this so that is included as well.
Please let us know if you need other info. Thanks
Images (Click to enlarge)
CBEEEEE
MEMBER
1 POST
Diagram is for automatic transmission overdrive sensor. I'm looking for Overspeed switch/sensor on manual transmission. Looking for Overspeed Switch/Sensor, not overdrive sensor.
