2001 Dodge Ram not sure
181,000 MILES • V8 • 2WD • AUTOMATIC
OZZY_ZEPPELIN
i just bought this damn truck and it was running fine but out of nowhere it started jearking when goin down the road it sounds like the engine has a minor miss in it but was woundering if that sounds like the tranny or what
Feb 16, 2010 at 12:08 PM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 16, 2010 at 12:12 PM
