Electrical problem
2001 Dodge Ram V8 Two Wheel Drive Automatic
When my truck is cold it will start normally. When it is hot it will not start. The engine will not turn over and there is no starter clicking as if it will attempt to start. I turn the key to start and nothing happens. The lights will work and all the instrument panels lights are working properly. Once it cools down for a while it will start normally. This repeats itself once it is hot and the engine is shut off. I have a brand new battery and there is no corrosion of the terminals. It has a full tank of gas. Could it be the starter relay or the fuel pump relay? What is your suggestion?
Sep 27, 2009 at 9:29 AM
