2001 Dodge Ram jerking while driving
UNKNOWNMAILMAN
Engine Performance problem
2001 Dodge Ram V8 Four Wheel Drive 58,000 miles
There is jerking in the drive system as if it isn't getting a steady flow of gas or transmission slipping.
It will run perfect after sitting all night, for a short spell anyhow, then it starts, especially upgrades on the freeway. Help!
Sep 22, 2009 at 1:13 PM
  • 110,248 POSTS
If the engine is missing, the check engine light should have come on to identify a random missfire. Has that happened? Also, have you checked the fuel pressure? A weak pump or clogged fuel filter can do the same. Is the ATF full and clean? It should be red in color. Also, does it smell burnt? Does the trans slip in any other gear and is it shifting properly.
Oct 3, 2009 at 6:03 PM
