2001 Dodge Ram ignition switch
60,000 MILES • V8 • 4WD • AUTOMATIC
MONKEY01
My dodge ram 1500 pickup truck the ignition switch will not turn w/ key in it! Could it be a blown fuse? If, so where will I find it? What else could be causing this problem?
Apr 15, 2008 at 11:45 AM
BMRFIXIT
  • 19,053 POSTS
no fuse for the ignition key
try to start and if still wont start
remove the key and turn it 180 degree and try again try to turn it back and then forward
and if still no luck you need a new ignition cylinder
Apr 15, 2008 at 1:14 PM
