2001 Dodge Ram Ignition
74,500 MILES • V8 • 2WD • AUTOMATIC
IAPMC424
the ACC. side of the Ignition Switch is not working how can this be repaired
Sep 18, 2009 at 12:44 AM
JDL
  • 16,098 POSTS
Check fuse 14--50amp in the power distribution center under the hood. Use a testlite, the fuse circuit should be hot all the time. If that checks out, check the red wire with white tracer at the ignition switch connector, it should be hot, if that is ok, the only thing left, that I know of, is to replace the ignition switch.
Sep 18, 2009 at 2:32 AM
IAPMC424
That Was it the terminal was dirty
Thank You very much
Sep 18, 2009 at 2:48 AM
JDL
  • 16,098 POSTS
I'm glad you got it going your way.
Sep 18, 2009 at 4:04 AM
