[quote:86485677fd="niederp"]Drive Train Axles Bearings problem
2001 Dodge Ram V8 Two Wheel Drive Automatic 87000 miles
I need to have the front two wheel bearings replaced, how much should that cost?[/quote:86485677fd]
Would help to know what size Ram, 1500, 2500, 3500 whether Heavy Duty. Is it a pick up or a van.
The cost will depend on whether the Hub Assembly is bolt on or if it has to be pressed out and new pressed in.
If it is Bolt on you could possibly handle the job and save quite a bit.
Feb 26, 2009 at 10:00 AM
