2001 Dodge Ram headlight problem
15,900 MILES • V8 • 4WD • AUTOMATIC
FRIELTLF
right side dim headlight doesn't work I;ve replaced the buld the socket and the plug the bright works but no dim.
Jan 10, 2010 at 3:14 AM
  • 110,248 POSTS
You will need to trace the power wire to the socket from the socket back until you locate where the power is lost. I am assuming you have already checked to make sure the socket is getting power. Also, keep in mind this could be a head light switch or multi function switch on the steering column causing the problem.
Jan 14, 2010 at 2:50 AM
