2001 Dodge Ram engine dies when braked
83,000 MILES • V8 • 4WD • AUTOMATIC
WISFARMWIFE
on the way to work, when I braked, the engine died, and would not restart. It sounded rough when it did try to restart. My boyfriend did put a chip in it a few weeks ago.
Aug 13, 2009 at 4:56 AM
DANAUTHIER
  • 156 POSTS
Is your check engine light on? If it is, have you had it checked to see what codes are in it?
I take it the chip that was installed is an aftermarket performance chip. Performance chips change the factory fuel settings and may be causing your issue. You can try changing the chip back and see if the condition clears up.
I did check and found no technical service bullitens or recalls for this condition.
Dan
Aug 13, 2009 at 5:24 AM
