2001 Dodge Ram Drive shaft
92,000 MILES • V8 • 2WD • AUTOMATIC
JBAUGH03
What can happen to the transmission if there is a dent in the drive shaft?
Apr 29, 2009 at 9:14 AM
  • 110,248 POSTS
Has the dent caused a vibration?
May 12, 2009 at 3:41 AM
JBAUGH03
Yes the dent has caused a vibration.
May 12, 2009 at 7:20 AM
  • 110,248 POSTS
It will end up taking out the output shaft bearing in the trans, u-joints, and pinion bearing. You should replace it or you're going to end up with other problems.
May 12, 2009 at 1:21 PM
JBAUGH03
Thank you very much
May 12, 2009 at 11:35 PM
  • 110,248 POSTS
Not a problem. If you have questions in the future, let us know.
May 13, 2009 at 4:46 AM
