2001 Dodge Ram clutch
2001 DODGE RAM
127,000 MILES • 6 CYL • 2WD • MANUAL
PINKPAJAMA
When installing a new clutch is it customery to also change the clutch master cylinder, slave cylinder and throw out bearing?
What will happen if only the clutch is replaced?
Jan 3, 2010 at 10:20 AM
  • 110,240 POSTS
What I recommend is replace the clutch, pressure plate, and throw-out-bearing. That is the standard. In fact, when you purchase a clutch kit, that is what it comes with. IF the slave is good, let it alone.
If you have other questions, let me know.
Jan 8, 2010 at 4:01 PM
