Engine Performance problem
2001 Dodge Ram V8 Four Wheel Drive Automatic
I have a dodge ram 2001 1500 4x4 offroad package 5.9L motor that the check engine light keeps coming on when i use the obd2 scanner the codes i get is "lowemissions leak and high emissions leak" I have replaced the gas cap (common problem) the solinod uder the hood mounted behind the headlight bracket and also one of the hoses going to the canister midway under the truck mounted to the frame. any suggestions or idea's what i might be overlooking? Thanks
Mar 13, 2010 at 1:21 AM
