2001 Dodge Ram ABS & brake lights on
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
MICHAEL DIVINE
My ABS & brake lights came on at the same time. I have been driving the truck a month and the brakes work fine. All four disc brake pads have been replaced 6 months ago. All the electrical breakers and break fluid is fine. Can you help me?
Jan 1, 2010 at 11:56 AM
  • 110,244 POSTS
Chances are there is a bad brake sensor. Have you had the computer scanned? Most parts stores will do it for free.
Let me know what you find.
Mar 1, 2021 at 4:39 AM
MYZ92
It is your abs speed sensor in the rear axle. if your speedometer doesnt work till a certain speed and your odometer isnt working too, that is your problem its all connected
  • 110,244 POSTS
If you are having speedo problems, that could be the problem. You're not going to believe it, but I just went down my driveway and the same thing happened. However, my brake pedal went with it, so I know I blew a brake line. However, if your speedo is working properly, check the sensors.
