2001 Dodge Ram ABS & brake lights on
MICHAEL DIVINE
  • 2001 DODGE RAM
  • 6 CYL
  • 4WD
  • 200,000 MILES
My ABS & brake lights came on at the same time. I have been driving the truck a month and the brakes work fine. All four disc brake pads have been replaced 6 months ago. All the electrical breakers and break fluid is fine. Can you help me?
Friday, January 1st, 2010 AT 7:56 PM
  • 109,885 POSTS
Chances are there is a bad brake sensor. Have you had the computer scanned? Most parts stores will do it for free.
Let me know what you find.
Monday, March 1st, 2021 AT 12:39 PM
MYZ92
It is your abs speed sensor in the rear axle. If your speedometer doesnt work till a certain speed and your odometer isnt working too, that is your problem its all connected
  • 109,885 POSTS
If you are having speedo problems, that could be the problem. You're not going to believe it, but I just went down my driveway and the same thing happened. However, my brake pedal went with it, so I know I blew a brake line. However, if your speedo is working properly, check the sensors.
