2001 DODGE RAM 2500 DIESEL
SIPPY
I WAS DRIVING DOWN THE ROAD AND IT JUST DIED LIKE SOMEONE SHUT THE SWITCH OFF WAS RUNNING FINE BEFORE HAD NO TROUBLE WITH IT AT ALL NOW IT WILL JUST TURN OVER FOREVER AND NOT EVEN TRY TO START
May 3, 2007 at 2:35 AM
LES DANE
  • 52 POSTS
Disconnect the rubber fuel line from the discharge side of the fuel filter housing. Connect a short hose to filter housing and place in a small container( 2 liter soda bottle, etc). Turn key and bump the starter. This will allow the low pressure fuel transfer pump to run for 20 to 25 seconds. If you just turn the key on the pump will only run for 2 seconds. @ the end of the run cycle you should have 40 or more ounces of fuel. If you get no fuel or very little fuel then start troubleshooting the transfer pump.
May 5, 2007 at 4:58 AM
