2001 Dodge Ram 2001 Headlight Problem
152,000 MILES • V8 • 4WD • AUTOMATIC
DIGGINCOWBOY
My truck came with sonar projecter headlights on it. Since I have owned the truck, the high beam indicator stays on in both the high and low beam settings. Also, when the dims are on it works great. When I switch to high beam everything goes very dim. I can't figure it out!!
Oct 8, 2009 at 7:11 AM
RACEFAN966
  • 5,029 POSTS
Before I can try to help I need to know if you have quad headlights or not. Meaning did it originaly have 4 lights in it or not. I also need to know if it is equipt with day time running lights so I can look over the right wiring diagram. Get back to me with the needed info and we will go from there.
Oct 9, 2009 at 3:13 AM
