2001 Dodge Ram Repeated Hub Failure
KURTIS25
I've had to replace the front driver side hub twice, I don't see any recalls notices...is there something I can do to prevent a 3rd replacement?
Jul 28, 2007 at 2:31 AM
DPWD23
  • 136 POSTS
Get an alignment, and check your ball joints and tie rod ends, and center link for play.
Any of these components worn out or damaged can cause a hub to malfunction.
Aug 2, 2007 at 5:14 PM
Suggested Repair
Have the front end aligned and inspect the ball joints, tie rod ends, and center link for play. Worn or damaged steering or suspension parts can cause repeated hub failure.
Conversation Summary
The owner of a 2001 Dodge Ram has replaced the front driver-side hub twice and wants to prevent another failure. The expert recommends an alignment and checking the ball joints, tie rod ends, and center link for play, noting that worn components can cause a hub to fail.
