My Dodge Ram is giving me a P1756 code. I have looked up the definition but can't find the solution? Anybody know how to fix the problem?
May 16, 2008 at 12:53 AM
BMRFIXIT
✓Experienced Mechanic
Its a tranny issue
possible cause:
solenoid pack connector 5-volts supply circuit open
governor pressure sensor defective
tranny fluid burnt or oil pan contain excessive debris (change fluid and filter )
tranny governor pressure out of range
tranny leaking internally
defective PCM
defective valve body
check fuses
May 16, 2008 at 12:38 PM
