2000 Dodge Ram no spark from primary
133,000 MILES • V8 • 4WD • AUTOMATIC
SFTBALLMOM17
The truck will start most times but when it gets hot it wont start till it cools off and we have found that there is no spark from the primary. Where should we start to fix this problem. We have already replaced the ignition coil.
Oct 22, 2010 at 5:13 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Oct 22, 2010 at 7:11 AM
