2000 Dodge Ram lack of spark
126,000 MILES • V8 • 2WD • AUTOMATIC
TIM SEASTRAND
i have good spark coming into the distributor from the coil but none coming out to any plugs. i have swapped the cap.rotor and the camshaft position sensor under the cap still nothing. thanks
Jan 15, 2010 at 5:15 AM
JDL
  • 16,098 POSTS
Hi, thanks for the donation. If you take the coil wire loose from the cap and hold close to engine ground, engine cranking, can you see a spark jump.
Engine cranking, does the rotor turn? All battery cables and engine grounds, ok?
Jan 15, 2010 at 6:03 AM
TIM SEASTRAND
after rechecking i find a very weak spark . i removed the coil and checked resistance per the manual. secondary ok, primary slightly out of spec 1.3 vs 0.96-1.18. is this critical?
Jan 15, 2010 at 11:10 PM
JDL
  • 16,098 POSTS
A weak coil is a possibility, plus the other suggestions. Sorry about the late reply, I've been having problems with mail.
Jan 19, 2010 at 12:57 AM
