2000 Dodge Ram Injector Circuit Cylinders 3,4 & 8
90,000 MILES • V8 • 2WD • AUTOMATIC
JAMESJ
  • 5 POSTS
Yes I did the code diagonstics on my truck and it read P0203,P0500, P0204 & P0208. After I already changed my cylinder for injector. Helped a little but not much. What does Injector Circuit Clyinder mean? How do I fix it? Thanks so much.
James
Feb 10, 2008 at 1:51 AM
MERLIN2021
  • 17,250 POSTS
The P0200's means the injector circuit on that particular position is malfunctioning, with this many I would check the main harnes to see if it is plugged in securely, P0500 is the VSS, or vehicle speed sensor malfuntion.
Feb 10, 2008 at 2:02 AM
