2000 Dodge Ram How do I purge the air out of the coolant sy
WZSGURL2002
Engine Cooling problem
2000 Dodge Ram Two Wheel Drive Automatic
The truck is overheating. We replaced the thermostat; water pump, gaskets and hoses. Still overheating. The instructions to the water pump state to "Purge system of air". How is this done?
Aug 6, 2010 at 12:01 PM
  • 110,244 POSTS
If there is no bleeder on the thermostat housing, remove the heater core return hose. Do this when it is cold because coolant will come out. Only run it for about 10 seconds and all air should be out.
Let me know if it helps.
Aug 6, 2010 at 4:35 PM
