2000 Dodge Ram Heater
115,000 MILES • V8 • 4WD • AUTOMATIC
SMITTY1946
My heater is going in and out. It sounds like the door is not closing all the way to let the heat in. I got under the dash and sprayed some lubricant on the lever that pulls in and out when you switch from cold to hot. It seemed to be going all the way in and out properly but it will only blow hot air if you give it some gas. when you let off the gas it will blow warm for a minute and then blow cold. if it is the door not opening or closing, how do I get to it and where is it located
Dec 30, 2007 at 2:38 PM
BLACKOP555
  • 10,386 POSTS
you have to go under the dash, to me when you say it wont work unless you give it gas, it sound like you have a bad vaccum line or a electric motor if you have a vaccum or electric operated blend door.
Dec 30, 2007 at 2:41 PM
